Listbox
• Page 2 of 3 • 1, 2, 3
Re: Listbox
Use:
Modded for RJHollins user case
now support this feature
CTRL+Mouse Left Click to
Select or Unselect Multi Item,
SHIFT+Mouse Left Click to
Select Multi item in range,
can work in mixed mode.
use the arrow key
to push the selected item to the output array,
and after it remove the item from the list.
It receive new item from the input array
"add_items", to the current list.
Updated: added better external item selector,
now switch and respect the items in view range
Updated: added drag and drop item reorder
Bugfix: reorder item safe guard
Update: added separate output for current list
Fix: style formatting
use the arrow key
- Tronic
Re: Listbox
Tronic wrote:Use:
use the arrow key
"add_iems", to the current list.
Well, done! And sorry, Mr notMe xD
Re: Listbox
Oh my ... did not expect this
Thanks TRONIC ... back later to check this out more !!!
Re: Listbox
little update in the previous post, I hope it now works well:
now switch and respect the items in view range.
- Tronic
Re: Listbox
another small update in the preview post
- Tronic
Re: Listbox
Got to do a fast check ... man this is such a cool feature.
Did hit a RUBY error ... something to do with 'too small value ... need to be zero. Will investigate more.
Re: Listbox
RJHollins wrote:Got to do a fast check ... man this is such a cool feature.
Fixed in last update r3
and added an output for the current updated list.
- Tronic
Re: Listbox
Cool ... was just coming back to ask about the updated list part.
I need to save the final list to disk [already have that part].
Going to check r-3.
Gonna say again ... what a useful GUI function. Thanks TRONIC for designing this.
of to test ...
Going to check r-3.
of to test ...
Re: Listbox
so far ... Real Good !
The updated output list [an important feature] looks to be working just fine.
I'm going to tie this in to a SAVE/LOAD routine, so that this 'update list' can be maintained for use with this special utility I'd like.
In function ... I'm a beta-tester, and we get .DLL update files. Manually, we have to make copies of this .DLL and COPY/RE-NAME them into 40+ different filenames [using the original DLL as the source].
After a few hundred times doing this, its not as much fun.
With the generous help from FS members here, this is a nice/useful utility, and be a real time saver.
For the respected GURU's here ... this little utility would be a piece of cake. Me, on the other hand, rassle ever bit of the way. It helps me RELAX
I'm getting better now
The dual list-box, with list control is really the icing on the cake.
With almost all the basic functioning in place, I'm starting to think of the general GUI layout. This will be one of the first EXE FStone project for me. [most everything else has been VST stuff].
ok ... back to work here ... will post back.
thank-you
thank-you
Re: Listbox
Very nice Tronic!
Are there any plans to add preset support? I realise the available list contents are set at edit time but it might be nice to be able to save the selection state in presets.
